Hello Mike,
Fantastic work there.... DV is using the Tremec TKO on the Coupe and the front or mid shift location with the B&M shifter is the choice to make due to the dimensions on the Coupe.
I used the Tremec TKO on my Unique with the standard rear location and the forward raked shifter from Enzo at finishline worked, it was a simple two bolt installation for the shifter.
My SPF also used the Tremec TKO with the rear shifter location and the forward raked shifter.....
Tony R.
