Old 10-25-2002, 05:52 AM
Hal Copple Hal Copple is offline
Cobra Make, Engine: Superformance, 396 CI
i have a failed Smith's oil temp gage, and an Autometer replica gage that was defective out of the box. I called Autometer about it, they did promptly send a replacement, and told me the mechanical gage's line and sensor was filled with Ether, to expand and cause the gage needle to work.
I was smarter the third time, as putting in a gage is a two hour job. Here is what i suggest to check your gage. Remove the sending unit, and put it in boiling water. Assuming you are at sea level, be sure it reads about 100 degrees C, or a bit less at some altitude. My first bad Autometer only got to about 60 degrees in boiling water.
It also depends on your sending unit location, when i had my sending unit in the oil filter mount, it read higher than when i had it in my sump. My Aviad pan has a sump port of sending units. IN my Windsor at steady cruise, in "winter" it will read a bit below my 80C water temps (185 'stat), in summer it will read a bit higher. It will get hotter, up to 100 C max in hot stop and go.
I bypass my oil cooler in the winter, in order to get my oil temps up to a reasonable temp. Too cool and it won't evaporate fuel and moisture, you should run about your engine temps to have your oil last the longest without contamination.
So, i suggest first checking your gage, easy to do. Let us know where your sending unit is, and if your cooler is hooked up or not.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
