Mike,
Congratulations on firing that bad boy up. Did you get your bellhousing dialed in? I just fired mine up Wednesday as well. When I primed it with the drill motor I had about 70lbs and about the same at 2500rpm cold. Once the
oil temp came up I had about 45lbs at 2500rpm.
Good talking with you the other day, Steve
