This is the information from Comp Cams
Part Number 35-324-8
Engine 1969-present Ford
351ci,
Windsor,
8cyl.
Grind Number FW XE270HR-12
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.544 0.544
Duration At 0.006 Tappet Lift 270 276
Valve Timing At 0.006
Open Close
Intake 27 63
Exhaust 74 22
These Specs Are For The Cam Installed At 108 Intake CL
Intake Exhaust
Duration At 0.05 218 224
Lobe Lift 0.32 0.32
Lobe Separation 112
Recommended Valve Springs 986-16
Would this cam be any good for my requirements?
