Speedo cable lube?
Hi
Running my cable route from the tremec tko to the reverse adapter on my speedo above the tunnel.....what a tight run......supposed to be fairly loose so as not to bind anywhere.
Hell that's easier said than done.....coming off the tranny, this puppy wants to run straight down into the ground, let alone get it to turn up loosely, go by the drivers side of the tranny/scattersheild and then thru the flat panel above the scattershield ........one big 180
by the way what are guys using for cable lube, if any?
Tim
