Old 10-28-2002, 09:59 AM
rdorman's Avatar
rdorman rdorman is offline
Renegade Nuns on Wheels
Default Thanks guys
Daniel.
You hit is right on the nose about the cam. It is the Fords motorsports cam. Windage tray and 'scraper' was added when I changed the pan. The tray is the type that mounts in the pan and not to the mains. I only use contact adhesive for the gaskets as well. But I did seal the ends with red rtv. I kept the 'turkey' pan but cut off boths sides where it meets the heads and the crossover is blocked.
I am looking to extend it up a bit. With the HP curve being completely flat from 5300 to 6100, I think we can. So how about a Blue Thunder intake and 770 vacuum secondary street avenger carb? Could I expect maybe another 20 or 30? How about advancing (retarding?) the cam a couple of degrees?
I do not want to hurt the drivability that I enjoy now. Simply want the engine to be all that it can.
Thanks
Rick
