BigJohn,
It will come out, but it is tight. We've found the easiest way is to push the side vent out, getting full access to the MC. (Hopefully it is only put in with some type of caulking.)
If the tub is painted, chances are you will scratch it. Break the lines loose too, then try to remove it.
Hope this helps.
DV
