Thread: Cam question
Old 10-30-2002, 12:44 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
So Mr. Fixit-
Based on your last response, I have the following question. I want my motor to do the same as Mr. Mike described. Comp. will be apx. 9.8:1, edel heads, blue thunder intake, holley 750 vac. secondary, rear end gears will be 3.31 with Tremec TKO II. Do you think 238/246 is too much duration on both I and E to accomplish the stated goal. If so, what specs would you recommend?
Thanks for your help,
Mike
Replica is not a dirty word.
