Old 11-04-2002, 11:30 AM
webebob webebob is offline
Cobra Make, Engine: SPF
You don't have to have another starter. You can wire around this one. The problem is that you must have wired a jumper from the starter to the solenoid on the starter. This is a no-no. this causes the starter to act as a generator when you let up. The generator then back feeds the solenoid and causes it to hange. Starter life will be short.
You can send the wire from the key switch to both solenoids, or you can eliminate the solenoid not on the starter. A small relay from radio shack can be used if a temp terminal is neeeded for balast resistor or the like.
Bob
