Old 11-05-2002, 07:52 AM
kountzecobra's Avatar
kountzecobra kountzecobra is offline
Probably thermostat housing gasket or timing cover gasket seeping a little bit. I would try to re-seal thermostat housing again first and file the gasket surface to make sure it is flat. BTW, you really need to remove those rubber caps and install a molded bypass hose. Water bypass is important when thermostat is closed. If thermostat ever sticks shut- then ZERO water circulation!
David Shelton
Lone Star Gashole!
