Old 11-05-2002, 01:48 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Why do you guys want AN radiator hoses? Your cooling system is not under great pressures, and most of you will still have to run a clamp-on adapter to mate the hoses to your radiator. Not to mention the bypass hose from the waterneck to the pump. They're heavier, much much more expensive, harder to plumb, no benefits over rubber hose, what am I missing here?
