Coolant Leak
Hi,
One thing you might consider is the intake to head coolant passages/gaskets. If your running late model heads on a early type intake(coolant passages), you might be getting a miss-match. This will seep a little coolant, especially from both sides and not only from the right side where the thermostate housing and bypass hoses are.
Tom Lucas,, FE Specialties 916-339-0427.
Tom Lucas, FE Specialties Sacramento, Calif. 916-339-0427. Our Engines are designed and engineered, not just thrown together. I design engines for every application. From mild street engines for torque to mid type performance engines for Cobras and Mustangs too fullout Race engines for Nascar and NHRA.
