Old 11-08-2002, 11:54 AM
FE Specialties FE Specialties is offline
Hello Cobra 427 mnsi,
Well there's a lot of things to consider on plug choice.
#1 is availability. For the older type 18mm size plug, Your choices have been reduced from 20 years ago in the number of heatranges that you can get!!
Right now its either cold or hot, with no in between.
The old bf42s use to be good for a performance motor that ran on the street and had a tendency to load up the plug. This was a mid range heat range plug that offered a solution to extended street driving.
Now, this is no longer available. You have to run either a Autolite 45, which is really an old bf82, or the previously mentioned bf33s. The Bf33s come in either the standard version, or you can get them in the race plug. Their the same basic plug, but the race version has a cut back bridge for the electrode, and is a crome finish body instead of black. These 33s are really the old BF22s of 30 years ago. Same exact plug. So if you run them on the street they have a tendency to load up. They are a very cold plug.
So what is the gist of all of this.
I would run the Autolite 33s and keep my idle up around 1200 rpm in neutral. This helps the oiling of the lower end, ei. cam, lifters, piston skirts, and helps the intake track keep some velocity to keep the fuel suspended so the plugs wont load up. Its kindofa toss up these days. I remember that we used to run BF32s or 42s around the street for every day, and then put in a new set of 22s(the new 33s of today) when we would have a race to go to!!
This is also one way to handle the plug delema today. Run the 45s everday, and then the 33s when going to the track or whatever for more performance. Remember, a colder plug helps transfer more spark charge because the heat doesn't elevate the resistence in the electrode.
I hope this helps!!
Tom Lucas FE Specialties 916-339-0427
Tom Lucas, FE Specialties Sacramento, Calif. 916-339-0427. Our Engines are designed and engineered, not just thrown together. I design engines for every application. From mild street engines for torque to mid type performance engines for Cobras and Mustangs too fullout Race engines for Nascar and NHRA.
