Old 11-09-2002, 01:53 PM
Tony Radford's Avatar
Tony Radford Tony Radford is offline
Cobra Make, Engine: Unique 427 SC, Southern Automotive 427W Stroker
Default If I had, I'd shoot myself.
I just got my car back from the shop (two days). The purpose of the trip was to fix an oil leak. It was dripping from the bell housing, so I assumed it was a rear main seal. It was. But during the disassembly process, it was determined that my driveshaft yoke was trashed along with the associated bushing in the trans. Fixed that. Clutch was a standard-duty clutch, which was scorched, as was the flywheel. Got a new King Cobra clutch and a billet steel flywheel. Clutch is great. But I still have the leak. It's much smaller, but a leak non the less. The shop put a sleeve on the end of the crank along with the one-piece seal. Replaced the pan gasket. Alas, I saw another drip at the bottom of the bell housing. I'm running Mobile 1, 5W 30. Is it possible that I will just have trouble keeping it all in the engine? It doesn't drip enough to ever have to add any, but I feel like these guys did a very thorough job fixing it. I can't believe they did anything wrong. I did crank some serious Rs on the way home from the shop. Any ideas?
Tony
After a good hard ride.....oil pressure is over 50, temp is below 190, she idles and no new dents. LIFE IS GOOD!
