Old 11-09-2002, 05:24 PM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Rick, 60-70 amps? I wish mine had that, I have 30 something and your right, the lights are a little dim at idle.
Bubblegum? Your killing me! I've never seen the 3 micron but you may be right, my catalogs only show the 60 & 115.
I use the 10 lbs per 100 hp guideline or 75-80 lbs on the aluminum engine and 65 lbs on the Cobra. Both engines underdrive the oil pump 50%; pulleys are 32/16 on the Cobra and 40/22 on the Aluminum. I turn the Cobra 7000 and the aluminum engine 8200 when there's traction and 7500 or less when the track slicks off.
480 ci and 15 lbs! what do you think that will make? 8-900ft/lbs?
You want to go shopping? PRI show is the week after Thanksgiving in Indy. I'll be there... dreaming only.
Scott
