Old 11-09-2002, 09:32 PM
ScottJ Scott in the mid 90's Oberg claimto fame was they could catch particles down to 3 microns. I wonder what the restriction from the filter was in gallons of flow?? How big a tank are you running for your dry sump? Why not put a mini alt on the car with 60 or 80 amps? You know their are other places to put a mini alt. No not in the wheels. Mr driveshaft spins and is doing nothing that would hurt or affect the alt. All you need is two wires or one if you like and away you go. 38 in the front and 60 pushing out the back. People will laugh but I have seen it work. I have a very small cam 501-533 I may go to a 530- 566 next step up. Hprw should be about 670 tork about 740 no slicks the Jag rear will not hold up. I have done everything to it, 30 spline stub shafts,chromemoly short shafts, watts linkage for the rear, rear cap girdle for the carrier. Locker Detroit. I want a big flat fat tork and hp line to 6500rpm. The G-Force will handle the power. Scott are you going to come to Run&Gun in Oct 2003? Hope soon want to see your car run. Beddy by time, the other half is in a teddyyyy gottogooooooooo later Rick@#$#$$%%%^^&**&!@#
