Dave, are you using the current coil over suspension or the older MGB setup? There is a huge difference. I swapped to the coil over system and all of the problems with the old front end (including the shakes) went away. Decooney is probably right too about the front ride height. I lowered mine a bit mainly to reduce high speed lift and I experience no shake at any speed, even WELL above 100 mph. BTW, I am running BFG's on PS Engineering bolt-ons. Good luck sorting it out.
Tropical Buzz
