To Mr. Fixit, it is just a "big honkin cap with sparkplug type terminals". No coil in the cap. Ford Motorsports has a conversion kit that adapts the larger diameter HE...... errrrr I mean sparkplug terminal cap (my bad?) to the early ponts style distributor. I plan to look into Kountzecobra's suggestion for a CarQuest cap. All I want to do is remove the "honkin" cap and adapterin order to clear the turkey pan without having to either swap out the Ford Motorsport ignition wires or use terminal adapters. I know, PICKY PICKY.
Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
