Jeff Neely Your the leader.
Go luck with the motor. They did not cut the cylinders to a standard size? Make sure that a bore plate is put on that motor before the cylinders are cut. Does this motor have the oiling system drilled out to blueprint spec? Have your machinist check that block out good before you due any machine work. I have only seen a rough cast, hope the finished one is alot better. Take some pictures of it when you get it. Rick Lake
