  #1585 (permalink)
Old 11-15-2002, 05:29 AM
Hotfingrs's Avatar
Hotfingrs Hotfingrs is offline
Cobra Make, Engine: EM cobra, 450 inch sbc running a best ET of 9.14..so far..ALL MOTOR...approx 800 horse.............ERA with 482 FE..All Aluminum Engine
Send a message via Yahoo to Hotfingrs
Subject: stupid hints
> >Stupid Hint #1 If you are choking on an ice cube, don't panic. Simply
> >pour a jug of boiling water down your throat and presto! The blockage is
> >almost instantly removed.
> >Stupid Hint #2 Avoid cutting yourself while slicing vegetables by getting
> >someone else to hold them while you chop away Stupid Hint #3 Don't buy
> >expensive 'ribbed' condoms, just buy an ordinary one and slip a handful of
> >frozen peas inside it before you put it on.
> >Stupid Hint #4 Putting just the right amount of gin in your goldfish bowl
> >makes the fishes' eyes bulge and cause them to swim in an amusing manner.
> >Stupid Hint #5 An empty aluminium cigar tube filled with angry wasps makes
> >a wonderful inexpensive vibrator.
> >Stupid Hint #6 Avoid arguments with the Mrs. about lifting the toilet
> >seat by simply pissing in the sink.
> >Stupid Hint #7 High blood pressure sufferers. Simply cut yourself and
> >bleed for a while, thus reducing the pressure in your veins.
> >Stupid Hint #8 A mouse trap, placed on top on of your alarm clock will
> >prevent you from rolling over and going back to sleep
Jack
XSSIVE .....
