Thread: Engine cooling
Old 11-15-2002, 06:53 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Mike, That's the radiator I use. I cut off the bottom of the old radiator support just below the mounting point. I then mount the radiator to the horizontal frame members with small "u" shaped brackets to fit the bottom of the rad. I use foam topper tape for an isolator. The upper brackets will need to be moved inward. Take a flat piece of steel and connect it between the upper bracket mounts, then drill holes for the new brackets so they will mount on the upper channel of the rad. The lower hose is a tight fit, you will need to get a hose with a 45 degree bend right out of the radiator. Also since you will have 2 radiator caps run a larger one on the radiator so if it boils over it will come out the in-line filler.
Don
