DV, did you ever manage to get that CR fuel tank & sender assembly in the mail or UPS? Want to get it duplicated (or improved) in stainless, then return it to you.
Have leftover set of VDO gauges; 7k tach, 160 speedo, 3 3/8"; volt, fuel,
oil, water w/ senders for
oil & water. Also have AM Sport Comp, 8k, 3 3/8" tach. New in box. Need 'em? Installed AM 5" speedo & tach, and Z series instruments instead.
Also have uninstalled Cobra length (37 1/2") Ididit steel column w/ dimmer button. It's non-tilt and won't work in a CR. Would work fine in a street rod where tilt is not necessary.
