Old 11-18-2002, 12:00 AM
Rick Parker's Avatar
The oil in the exaust is not a good indicator. Could be blown intake or head gasket (depending on the volume) or worse yet a cracked head. Check for water/coolant in the oil (and/or) oil in the cooling system. As for oil pressure check, the shear pin in the distributor shaft in the gear or the drive shaft itself. Keep us posted, best of luck!
........Rick
Rick
