Thread: Cooling hoses
Old 11-19-2002, 07:32 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Are you using a stock water pump or do you have an aluminium edelbrock or an electric water pump?
I am running an FE (428CJ) w/ the Edelbrock water pump. The water pump end of the hose is 2 1/4" dia and my radiator hose size is 2" dia. My hose goes under my frame so I use a 2" exhaust pipe bent at 90 degrees. I think my rad hose from my water pump to my 2" pipe is Gates #20615 and my hose going from my 2" pipe to my lower radiator is a Gates #21053.
I hope this helps you a little but I am not certain how the Mid-States radiator hose is positioned or directed on your car. Good luck with your build.
Clois Harlan
"Let's roll"
"Be part of Something Good
