Jack, Actually the trans has more pressure than the
oil. Most trannys can run up to 300 psi in the lines. NHRA has banned the use of rubber lines and clamps because of the pressures and possibility of rupture. The trans cooler in the radiator is just a tube that runs between the fittings. Not very efficient. Mike is right about the temps in the radiator. Not the same as engine temp.
Don
