289 build questions
I have a few questions concerning my 289 project. I purchase a 64' 289 short block about a year & a half ago & until now it has been sitting wrapped in plastic in my garage. It was rebuilt at 40 over on the cylinder, 10 under on the crank & has 9 to 1 cast pistons. I plan to put the car together for street use primarily but with decent performance characteristics. I am looking to go all out with this engine I just want it to be street fast & sound good. I am looking at this ford racing cam...
Advertised duration: 280 intake/290 exhaust
Duration at .050 in. cam lift: 204 intake/214 exhaust
Gross valve lift: .448 in. intake/.472 in. exhaust
Lobe separation: 107 degrees intake/117 degrees exhaust
Peak horsepower rpm: 4,750
Peak torque rpm: 3,500
RPM range: 2,500-5,500
I would also like to use the cast iron Ford racing heads with 60cc combustion chambers, 1.84 in. intake/1.46 in. exhaust valves
I also would like advise on to or not to use arp bolts on the mains. I will be using them on the rods & will likely go with arp studs for the heads. The bottom end is already assembled with what are probably stock fasteners
Any other suggestions would also be helpful
Hyde D. Baker
