Thread: 347 Stroker..
Old 11-21-2002, 01:49 PM
SSSnake's Avatar
SSSnake SSSnake is offline
Cobra Make, Engine: ERA FIA #2078. 331 stroker, sportsman block built by Evanuik Performance. 450hp
Send a message via AIM to SSSnake
We also didn't like the oil ring problem with the 347 and decided to go with the 331. It is a sportsman block, scat 4340 forged crank, forged JE pistons, ported and polished aluminum World Products Heads, comp cams custom grind .560" lift 230 duration, comp cams roller rockers, 10.4:1 compression. It should come out around 420 hp and about the same in torque. We are gonna put it on the dyno after it is together so i can post real results here in a couple of weeks.
Glenn
