Old 11-22-2002, 08:53 AM
richard lucero richard lucero is offline
Default Holes in carpet
A helpful hint when cutting holes in carpet. I just installed my 5 point belts. I used a piece of tubing and sharpened the end with a file, positioned it where I wanted the hole and drilled thru the rug and the insulation . I then drilled my hole where the "plug" was removed. Worked great. You do have to redress the tube after a few holes but the holes come out great!!!!! If you cant find the right size tube, drill a piece of round steel and sharpen the end. Richard
