Did you check the pulley clearance with the fan belt tensioned? I wasn't sure if you indicated if you checked the pulley with or without the belt on. If there is any small alignment problem the alternator vanes maybe touching the alternator chassis as someone suggested. If you checked with the belt off, you may have "uncocked" the pulley which means you may still have the problem.
