Old 11-22-2002, 12:40 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
The reason the beehive spring was designed was to eliminate the need to machine the valve spring pocket. It is the same diameter at of a stock spring on the bottom and gets bigger in diameter towards the top. No other advantage over a normal spring.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
