i am not sure how much trunk space you need but i just install a gas strut on mine. i will give you the part number and the run down, took about 30 min. and works great helps open when your over half way and when you close just lower and then drop. you could use a stronger one but i didnt find one with the swivel end i liked . one mightylift part and 2 screws. here we go. mightylift from autozone. 19.99 each. model number 95263 and 95273 the 95263 is for the rear. it has a small 2 hole bracket i attach at the base of the trunk toward the back. and then drill one small hole in the truck arrm on the left side. works great. you will loose a little of the left side of the trunk do to bar reaching across but is still get chairs in with out a problem . i used the other for the front. just drill in the front crossmember and placed a small L brack off of the front hinge drill and hole on each end . use the supplied bolt /cap ends and again you have a nice gas strut lift . the front will lift the hood once you are about 1/2 of the way up. email if you have questions or want pics. was fun and to easy. PS just make sure the length of the hood open is where the strut is at max extension dont want to put any undue stress on the fiberglass.
Well officer.. It was like this.
