Thread: Re: HOT STARTS
Old 11-27-2002, 12:20 PM
HighPlainsDrifter's Avatar
HighPlainsDrifter HighPlainsDrifter is offline
Cobra Make, Engine: F5 Roadster
Post
Curtis,
There are a couple fixes depending on how much $$ you want to spend.
1 - Put a on / off toggle switch in the power lead to the distributor. Turn the switch off,as you crank the engine[spins freely now] turn the toggle switch on and it will fire right up.
2 - Put in a msd adjustable timing control.You can vary the timing up to 15 degrees with the turn of a knob inside the car.
Perry.
