Old 11-27-2002, 02:54 PM
Jack21 Jack21 is offline
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Another question you need to consider is will your stroker WITH factory EFI fit under the closed hood?
CR had to make a special hood to fit a 302 EFI under it, and the 351W is taller still.
A carb'd 351W has minimal hood clearance with a Performer RPM, and the engine lowered 3/4" into the frame.
You may have to check out plenum options as far as height goes before springing for the $$$.
