Old 12-01-2002, 06:57 PM
Bill Wells Bill Wells is offline
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
the rule of going into reverse without grinding the gears is quite simply: " FIRST FIRST before reverse " ! when you stop your car, pause a millisecond from whatever gear you are in, go into FIRST gear and that stops the gears from spinning..then go right into reverse. presto , no grinding ...FIRST FIRST before reverse ! its like a hot knife cutting thru warm butter, smooth and easy. b
