Old 12-03-2002, 09:45 PM
JoeLafives JoeLafives is offline
Cobra Make, Engine: Unique 289 FIA,302 Crate,Holley 600cfm
Default Toploader won't go into gear
Was doing some clean up on my Unique FIA. I changed out the clutch line and also replaced a U-joint on the left back axle. In order to do so I was shifting the car into first to hold the rear. When I was finally finished I lowered the car and attempted to take it out of gear. It was stuck so I put the clutch in and started it up. Started up fine and I drove it around the block while attempting to shift it out of first. No luck, so I brought it back in and put it back up on jack stands. I crawled under and moved the shift lever and was able to get it out of first. I then started the car up and attemted to shift it back in to first no luck.
Any suggestions.
Best
Scott
HANDLE WITH EXTREME CARE: This product contains minute electrically charged particles moving at velocities in excess of five hundred million miles per hour
