Hi joe,
My guess would be that the clutch is not fully disengaging, leaving force applied to the transmission input shaft and gears. They don't shift well with the clutch dragging!! Since you were just working on the clutch lines, I'd check and make sure the system is bled well. Are you using an external slave cylinder or a hydraulic throw-out bearing? The thow-out bearings can be tricky to bleed.
Steve
