Old 12-04-2002, 07:09 AM
hcollado's Avatar
hcollado hcollado is offline
Cobra Make, Engine: Everett/Morrison- Boss 302 Stroked W/351W heads and a whole bunch of ponies
Default Remote Oil Filter Mount
Roscoe,
Wow, lots of toys under your hood. The unit I have looks identical to the one you are using. However, if I follow the indicated "In / Out" markings, it's going to bring the oil into the filter from the side and not the center. I thought the oil has to come in to the filter from the center hole and it exits filtered thru the perimeter holes?
By the way, my unit was plugged in the middle. I just drilled the plugs out and now I can see that it will work, but I want to get the plumbing right.
Thanks for your help.
Hector
Hector Collado
Everyday is a Holiday ... every meal is a banquet.
