Buzz, the feeling you describe is akin to my Yamaha V-Max..the "V-Boost" is similar to carb secondaries opening, along with hitting the cam peak, it comes on at 6,000 RPMs, and I can pass a loong semi in just seconds (like 2 to 3 seconds) even on a uphill grade... as long as I start out at say 5,000 RPMs.. the strokers you guys have are no doubt roughly similar to my incoming 514 in the heavier West Coast, in terms of performance... Georgia snake...you are in for a treat ! Take it easy on wet pavement and in the corners..learn all the little details of it's power curve and traction,...snakes can bite you!
When is your delivery date? Is it a turnkey, or roller/minus?
I am expecting my turnkey in less than 2 weeks...finally..you can imagine how I feel
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
