Old 12-05-2002, 09:44 PM
mkcobra mkcobra is offline
Default mighty lift
i just did this install. lots of different lifts and option.s the front is probably the most straight forward. i will lookup my part numbers and let you know. first you may want to decide how you will use the rear trunk space. i did the rear from across the lid. the shock could have been a little stronger but once your half way it will hold it up buy not take it out of your hand. the front one is just perfect it lifts once you are about 1/4 of the way up. only drawback is you need an 90 degree drill and very short drill bit to put the stud and tap the front crossmemer to install stud. i just measure my distance and then went down to autozone. here are the 2 part numbers. model number 95263 and 95273 let me know and i will email you some pics. Mike
Well officer.. It was like this.
