Old 12-08-2002, 07:31 PM
stuck's Avatar
stuck stuck is offline
Cobra Make, Engine: FFR3200, Carbed 351W, IRS, TKO600 RR
Unhappy Holley tuning quirk...?
I was trying to help a friend get his carb running decently and I am having a hard time getting the idle down to a reasonable level.
It's a new Holley 670 Street Avenger w/vacuum secondaries.
I dropped the idle speed as low as it will go. The idle mixture to start with was set at about half a turn out on each side. The front float was a little high and the rear is still about half way up the glass but I wouldn't expect it to cause this problem....? What should I check next?
Come on Tony, I know you know the answer...
Thanks,
Ryan
Ryan Logan
FFR3200 Comp - NASA #27 (ST-1)
TCC President '03
www.cuttingedgeracing.com
