Old 12-09-2002, 08:14 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
starwolf, you can use the Mustang II booster, it bolts right up to the CR pedal assembly. I use the Corvette master with the 4 wheel disc. It's NAPA # 36367. You will need to elongate the mounting holes to get the proper fit on the booster. You will also need to adjust the rod from the booster to the master. There are a few guys on the forum that have also used the Mustang GT master from the 4 wheel disc car.
Don
