Old 12-11-2002, 06:56 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Doug:
Don't be afraid of the cam you have. The duration and overlap is not too radical for the flow you have in the heads. I have another 10 degrees duration with about the same flow on the heads as you do. Idles at 900 rpm all day long and pulls strong from 2,500-6,000 rpm. Made 585 hp @ 6,000 rpm. on pump gas.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
