Old 12-18-2002, 06:28 AM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
A simple check regardless of the transmission would be to make sure the shifter boot is not binding against the shifter wand when in second. This is an easy fix providing it's the problem. Another check is linkage adjustment. This would occur only with an externally mounted shifter, i.e., top loader. Otherwise, you're looking at an internal problem, meaning the trans. must come out. The problem then may be the shifter sleeve is not moving into full engagement with the gear because of fork wear, a detent shoe spring is broken or who knows. Regardless, you'll have to get inside the transmission.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
