12-19-2002, 02:43 PM
Shell Valley Cobra For Sale
I really don't want to but because of events beyond my control, I must sell my prized possession. I am the original owner and builder. There's a lot of care and precision that went into building this car. Below is the text taken from my advertisement on the Cobra Country Web Site.
For Sale: Shell Valley 427S/C Cobra replica. 2000 Chrome Yellow base/clear paint, dual white stripes, black interior. Engine factory-built 351 Windsor w/roller rockers, mild cam, World Products Windsor cylinder heads, flattop Pistons, Edelbrock Performer RPM aluminum intake, Holley 4 bbl carb w/electric choke and vacuum secondarys, MSD 6A ignition w/MSD billet distributor, Milodon high-flow aluminum water pump, new Tremec World Class T-5 transmission, aluminum bellhousing, Centerforce clutch and pressure plate, stainless steel braided fuel line, functional oil cooler w/half-inch braided stainless steel lines and AN fittings, Milodon Low Profile 8 qt. oil pan, remote oil filter, billet aluminum fuel filter, pressure gauge, Holley RED electric fuel pump, Griffin aluminum radiator, dual electric pusher fans w/thermo relays, Ford 9" rear end w/3.50 gears, triangulated 4-link with rubber/poly bushings, disc brakes front and rear, adjustable coil-over shocks, upper & lower tubular A-arms, 17" Team III Halibrand wheels w/wheel locks, Low profile Nitto 555 drag radials on rear (315x35x17), Nitto 555NR Radials on front (245X45X17) (less than 300 miles on tires), removable transmission crossmember. Interior: custom brushed aluminum dash, black carpet, adjustable seat original-style (Shell Valley), heater w/2-speed blower, OEM-style door latches, OEM-style rearview mirror, MotoLita hardwood steering wheel, VDO gauges, RCI 5-pt. restraints, chromed fire extinguisher, Painless wiring fuse block, chrome-plated rollbar and side exhaust. Full car cover, custom aluminum pedal box cover, chrome-plated upper radiator support. Titled as a 1967 Cobra replica in Florida. Completed June 2001. 2500 miles. Plenty of TLC went into building this car. I am the original owner and builder. This car is a pleasure to drive as well as look at. $35,500. Will also sell open 2-axle trailer and all tie-downs $1500. Phone (904) 771-8568 home, or email: paul@campanales.com
I put several new pictures on my Web Site. http://www.campanales.com/interest.htm
The “large” links to pictures under the thumbnails are worth waiting for.
Thanks,
Paul Campanale
