Bill,
If you can give me a few more of the specs you want to use I can run it through my dyno program and give you a pretty close estimate to the horsepower, however the torque will be low. For some reason this program has always read torque from 20 to 45 pounds low depending on the setup but the horsepower readings have always been within about 5-10 of the actual dyno results and the RPM range has always been right on. Carb size, intake type, dual or single plane, cam specs and type of heads and exhaust system would be mostly what I need. Also as Jeff mentioned, are you going to port the heads or anything. Even pocket porting adds a good amount of power. Porting and matching the intake to the heads will help a lot too.
