Old 12-23-2002, 08:26 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
427 w/ 428 Crank = 454 cu in. 500 hp w/o porting, 550 hp w/ porting. Edelbrock heads with 2.19 intake and 1.73 exhast valves. About 250 degrees duration @ .050 lift with around .600 lift. 10.75:1 comp.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
