Wayne, you could also size the
oil ring and the top rings in the cylinders to see if they were the correct size for the application. Maybe they are standard and your block is .030 over. A quart every 50 miles leads me to believe that the top rings were not sealing regardless of the
oil ring. Good luck, scott.
