Old 12-28-2002, 11:29 AM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Default fittings
Gatorac:
Couple of thoughts: You will need 6 hose fittings that go on the hose that mate up to your listed adapters.
Check out your Southern plate: mine has to pipe fitting coming straight out; I also used 1 straight and 1 90 deg from this plate. The problem that arises is; the 90 deg must be installed first; it can't be screwed in with the straight in the way. This causes a problem because when the 90 tighened up in the pipe thread it was pointing the wrong way. Your stuck with being loose or a full turn tighter. If you have room, what I do again, is use two straights; that gives you unlimited flexiblity.
You might also use a oil pressure fitting; and gas line fittings
gn
