Old 12-31-2002, 04:37 PM
A Snake A Snake is offline
Cobra Make, Engine: Contemporary CCX33868 Sold. Just "playin' the boards now."
An easier way might be to look at water pump pulley spacers and alternator brackets.
If your new balancer was to be a direct replacement, it should fit. However, you might look at the spacer sleeve on the crank nose behind the balancer. As long as it fits the oil seal in the timing cover, it could be shortened to accommodate your set-back needs.
Al
"If some is good, more is better.
And too much is just enough."
--Carroll Shelby
