Thread: Engine?
Old 01-01-2003, 05:47 PM
bckroom bckroom is offline
Send a message via Yahoo to bckroom
StuM, Good choice in colors.(Same as mine #1239. There is a reason that combo is probably the most common, it looks the best. As far as engine goes, mine has a 380 hp crate motor. No oil leaks or problems in the first 1200 miles. It will go at least 130 mph and that is fast enough for me. This is my second Cobra and both of them are a handful above 120mph. I have said many times that these roadsters have the aerodynamics of a cement block at 100 plus. With that in mind, unless you just want to brag, 400 hp is all you need. .................Good luck....Rog
